Club323F • View topic - using revs to check timing ?
It is currently Wed Nov 11, 2026 11:20 pm
elesar
PostPosted: Wed Dec 28, 2005 6:18 am
Hi all
Just a quicky question... can the revs give you some indication that you're timing is right or wrong ?
My revs are constant at 700rpm , so can I assume that it's still ok ? or do you have to check the timing with a timing light or something ?
Any advise will be appreciated.
PostPosted: Wed Dec 28, 2005 10:46 am
It will probably idle fine if the timing is out. Only way to check is to use the markings on the cam pulleys/crank pulley.
I thought mine were out after I had the belt changed, but in actual fact they did the job right, the first garage yet for me. Last garage didn't tighten my wheel nuts.
elesar
PostPosted: Wed Dec 28, 2005 11:56 am
[quote="fastmike"]
I thought mine were out after I had the belt changed, but in actual fact they did the job right, the first garage yet for me. Last garage didn't tighten my wheel nuts.[/quote]
not like you need it or anything ... :error:
Thanks, I'll get the timing light in there and check ... do you know what the timing should be ?
PostPosted: Thu Dec 29, 2005 2:18 pm
Don't know to be honest.
http://www.club323f.com/club323f/forum/ ... php?t=2705
I got confused so just rotated the crank by hand and used a dial test indicator.
PostPosted: Thu Dec 29, 2005 3:13 pm
There's some funky thing you have to do that involves shorting two terminals in the diagnostic socket in the engine bay. This over-rides the ECU timing, otherwise the ECU keeps adjusting the ignition timing while you are adjusting it, resulting in unpredictable results .....
elesar
PostPosted: Fri Dec 30, 2005 6:29 am
great stuff gys ... the link is just what I needed .. Thanks ! :compress:
