Club323F • View topic - Help... Power Aerial?
It is currently Sun Nov 08, 2026 12:20 am
jon_r83
 Post subject: Help... Power Aerial?
PostPosted: Thu Mar 25, 2004 11:12 am
My aerial has buggered.
It starts to move but then stops, hasnt been used for a six weeks so thought it jus needed oiling but still dont work?
any ideas what could be wrong?
Cheers :?
scollinguk
PostPosted: Thu Mar 25, 2004 1:47 pm
I also had a problem with the aerial when i first bought the car, in which it kept going up and down of its own accord, so i rewired the remote turn on cable and now it works fine, so that would be my first port of call.
mazdaman mazdaspecialist
 Post subject: ariel
PostPosted: Fri Mar 26, 2004 9:41 am
if you can pull ariel up by hand if it comes up enough that is you should then be able to pull all the way up. clean & spray with wd 40 & try going up & down if not you will have to stip out motor from car then take it apart quite easy to do.
