Club323F • View topic - Cigarette Lighter
It is currently Sun Nov 08, 2026 12:19 am
hohohobigol
 Post subject: Cigarette Lighter
PostPosted: Thu Mar 18, 2004 9:30 pm
Got a problem with the fag lighter.
The actual cigarette lighter works ok, heats up and glows etc.
But when I stick in an adaptor for say my phone (or minifridge) they dont work. Briefly on occassion the fone wil light up for less than a second then, nothing.
The green surround of the 'hole' also doesnt light up.... which i dont know if it should, or if this is connected to the problem....
Anyone know.... or can help?!! :?:
Stealth
PostPosted: Fri Mar 19, 2004 9:52 am
Get a new one.
Or alternatively, you could get it out and check the wiring. I think you have to remove the surrounding dash to get to it though.
hohohobigol
PostPosted: Fri Mar 19, 2004 3:00 pm
By getting a new one im going to have to get the surrounding off anyway to fx it am i not...
So surrounds coming off no matter what........ ?
mazdaman mazdaspecialist
 Post subject: light
PostPosted: Fri Mar 19, 2004 3:23 pm
green surround only comes on with side lights. bstard job to replace lighter though
PostPosted: Tue Mar 23, 2004 10:44 pm
i had this prob in a previous car (cavalier). if you look inside the lighter you`ll see 2 spring clips that hold the lighter in when you push it. you could try levering these out a bit with a small screwdriver (gently). this might give a better connection. also try cleaning inside the lighter with a stiff brush, like a toothbrush. if you use colgate it`ll smell lovely!!!!
good luck :wink:
