Club323F • View topic - Engine Technology
It is currently Tue Nov 10, 2026 4:52 pm
jh1806
 Post subject: Engine Technology
PostPosted: Fri Jul 29, 2005 10:42 pm
I am wondering whether my wonderful 1.8 dohc lump has any variable timing on it, just for interest. I'm in the opinion that it might, because at about 4.5-5k revs, it lets off this wonderful high-pitched whine, which changes to an insane whine at 6/7k revs. It might just be the noise the engine makes, but i'm interested to know exactly what it's doing under there...certainly other cars i've been sat in that have variable timing systems (vtec, variocam etc) do start whining too.....
PostPosted: Fri Jul 29, 2005 11:31 pm
No variable valve system but I'm pretty sure the 1.8 has VICS (Variable Inertia Control System). This changes the length of the intake manifold.
jh1806
PostPosted: Sat Jul 30, 2005 10:43 am
How does it change the length of it? Surely its a fixed piece of metal to each cylinder's intake?
Marky Mark
PostPosted: Sat Jul 30, 2005 10:59 am
Does the V6 have VICS too Robbie...?
Don't you just love acronyms? The Japs certainly do....
PostPosted: Sat Jul 30, 2005 4:21 pm
I've a feeling the BGs had the VICS system, but as far as I can see, there's no way the BA's intake length can be changed dynamically. The early 1.8 BA's have a small resonator box between the airbox and throttle body.
Joe Mazda
PostPosted: Sat Jul 30, 2005 7:04 pm
Yep, 1.8 DOHC engines from the BG's have VICS - havent driven one without it so ive no idea what it does :D
PostPosted: Sat Jul 30, 2005 10:47 pm
It works by a series of shutter valves (look like throttle valves) in the intake manifold. They just direct the air along a different route. It is similar to the dynamic chamber thing Mark mentioned. The V6 has this also. A lot of Mazdas used the VICS system, the high power RX-8 has about 3 different intake manifold "tracks" depending on engine speed and the number of injectors it's firing.
edited to say... It's actually called VIRS on the V6, don't know what that stands for though Variable Intake Routing System maybe?
PostPosted: Sun Jul 31, 2005 10:17 pm
I guess these are ECU controlled are they?
PostPosted: Mon Aug 01, 2005 10:38 pm
Yep, the acutator valve looks like a distributor vaccum advance unit fixed to the inlet manifold. Follow the pipe and it should lead to a control valve with a 2 pin connector on it and another rubber pipe. The control valve is open & shut by the PCM as required.
jh1806
PostPosted: Tue Aug 02, 2005 9:43 am
That all sounds really cool....guess its the different air paths that make the whistle/whine.
PostPosted: Tue Aug 02, 2005 11:08 pm
The different air paths tune the intake tract to deliver greater than 100% intake volume at more than one rpm band.
