Club323F • View topic - clutch
It is currently Wed Nov 11, 2026 5:31 am
deep2005
 Post subject: clutch
PostPosted: Fri Jun 24, 2005 4:35 pm
Are you ment to be able to feel the enigne through your clutch pedal wen its not engaged? its like a grinding feeling in the pedal but not a noise. plus it dosent seem to want to go into 1st gear 1st time, is the cluth on the way out? i have been driving it hard recently
Stuart McB
PostPosted: Sat Jun 25, 2005 12:20 pm
Sounds like it could be the synchromesh has crumbled and the bits are floating about in the gear box oil. Drain the gear box oil and check for metalic debris. :( The clutch would smell of a horrible burning and would slip as well.
deep2005
PostPosted: Sat Jun 25, 2005 12:23 pm
how much would it be to fix :cry: its only done 48680 miles should it of happend? or was it from driving it hard? :(
Stuart McB
PostPosted: Sun Jun 26, 2005 6:47 pm
Couldn't tell you the cost, but it's just one of those things. You never know the oil change may or may not improve it. If you need a box then there's a couple of Mazda breakers in Birmingham, not too far form Northampton.
