Club323F • View topic - V6 Exhausts & CO Levels
It is currently Mon Nov 09, 2026 11:30 pm
Marky Mark
 Post subject: V6 Exhausts & CO Levels
PostPosted: Sat Jun 18, 2005 10:18 am
I know some of you guys have V6 engines with non-standard exhausts. What sort of CO levels are you getting during the emissions check that's part of your MOT test? The test station should give you a print-out. Also, has anyone had to replace a catalytic converter, and used a non-Mazda unit? Some places can supply a "sports cat", which is supposed to keep the CO level down but allow better air flow. I've just had one fitted and I have serious reservations about it, the car only just squeezed through the emission check. The reading was 0.19% CO, but the local Mazda dealer says a ZXi should be more like 0.02%, which is a big difference.
AndyH
PostPosted: Sat Jun 18, 2005 1:15 pm
I have a high flow sports cat. In theory, it should keep emissions down to the level of the standard cat, but I haven't had it tested yet (MOT due in Oct). Are you sure it's down to the cat? Did you have your figures checked immediately pprior to fitting the new cat?
PostPosted: Sat Jun 18, 2005 7:54 pm
not had mine checked yet with exhaust on so I dont know, will see if I still have CO2 reading from original tho
Marky Mark
PostPosted: Sun Jun 19, 2005 12:06 am
The car failed the MOT miserably with a CO at fast idle (2700 rpm - now part of the test) of over 0.6%. Replacing the cat brought this just within the limit for a pass (0.2%), but Mazda man reckons this is still too high for the car.
by the way note it's CO not CO2 they measure now....
Dragon Rob
PostPosted: Sun Jun 19, 2005 11:58 am
Ok, just passed my MoT on Fri, here are my results from the V6 (type R)
CO % vol 1.018
HC ppm vol 335
CO2 % vol 14.59
O2 % vol 0.75
Lambda 0.988
But as an import I get better limits anyway - CO % <3.500 and HC ppm <1200
p.s. these results are WITHOUT A CAT! :twisted::twisted::twisted:
Full Circle:-
Marky Mark
PostPosted: Sun Jun 19, 2005 8:33 pm
Rob your limits are WAY higher - the UK spec has lambda at 0.970 to 1.03 (mine 1.009) and HC at 200ppm (mine 59ppm).
Dragon Rob
PostPosted: Mon Jun 20, 2005 11:08 pm
Yep, the bonus of a rare import! :twisted:
Full Circle:-
Marky Mark
PostPosted: Tue Jun 21, 2005 9:05 am
Have been thinking that if the CO level is still high with a new cat then maybe one of the lambda sensors is failing. I think I read somewhere on this Forum that they can become inefficient due to carbon build-up, so that's something fairly easy (and cheap) to check. Also you can measure the electrical resistance of the sensor, which if it's above a set limit means the thing is faulty.
