Club323F • View topic - Clunky steering sorted
It is currently Mon Nov 09, 2026 10:49 pm
cybercom
 Post subject: Clunky steering sorted
PostPosted: Thu Jan 13, 2005 7:32 pm
At last I've sorted my steering problem (as in it clunked everytime I turned the wheel). The fault was the disc brakes....slightly worn with a large ridge which caused the pads to rise up onto then clunk down onto the disc again. New discs and pads and it's as good as new! AND THE LOCAL GARAGES (WELL 3 ANYWAY) SAID IT WAS THE STEERING RACK WORN!!
PostPosted: Thu Jan 13, 2005 10:00 pm
told ya it'd be the brakes :wink:
Tiswas
PostPosted: Thu Jan 13, 2005 10:06 pm
[quote="Ronin (Adam)"]told ya it'd be the brakes :wink:[/quote]
Well done that man =D>
cybercom
PostPosted: Fri Jan 14, 2005 8:48 am
Thanks guys, you were a great help and saved me serious amounts of money - just goes to show that talking to people with the same cars (and problems) are often far better than the professionals who only work on these cars maybe 10 times a year and often only then changing the oil and filter!
classmaz
PostPosted: Fri Jan 14, 2005 4:15 pm
found out my problem was caused by the cv and boot joint :( anyone know of anywere to get them cheap?
PostPosted: Fri Jan 14, 2005 4:26 pm
am sure somone bought one recently - do a search in the servicing section for CV joint - am sure they had the price on there too
tucker101uk
PostPosted: Fri Jan 14, 2005 4:31 pm
It was me!!!!!!!
I got one from my local motorfactors - all the parts were 60 quid...
Obv gave them to the garage to fit though.
TYPE Brad R Wills
PostPosted: Mon Feb 21, 2005 1:55 am
If you're still after a CV Joint - Try Www.partsinabox.co.uk.
MAKE SURE YOU TELL THEM IF ITS AN IMPORT and speak to Ian for a 10% discount.
As for fitting - once you;ve got that god dammed nut off its a piece of Pi55 to do it yourself......just make sure you re-tighten everything properly.
My steering is STILL clunking but seems to be improved after a brake strip and re-build.....therefore I am considering changing both the discs and pads as well as the left hand caliper which seems to have seized beyond repair (Dodgy boot on it)
