Club323F • View topic - rev light switch
It is currently Mon Nov 09, 2026 4:28 am
pop twang
 Post subject: rev light switch
PostPosted: Thu Nov 04, 2004 12:59 pm
A friend informed me that my reversing light was not working so off i went to get a new bulb. new bulb fitted and reverse light still not working. So now i'm thinking reverse light switch problems, maybe just a dodgy connection but can anyone tell me where it is?
Is it where i think, next to the gear lever under the central housing for the gear lever and handbrake?
Or, is it under the car?
Or, even plugged into the gearbox itself?
PostPosted: Thu Nov 04, 2004 1:22 pm
On mine the wire block connector by the gearbox was rotten. Its a black thing under by the air filter housing. All i did was snip the wires and fit a new block connector job done, the light works now :)
PostPosted: Thu Nov 04, 2004 1:36 pm
Hi Pop
Your last guess is correct - the switch is on the gearbox. Look at the gearbox from in front of your car. Look to the extreem right hand side, near the bottom - you should find the wires connected to a switch screwed into the gearbox housing - that's it. I did post an illustration some time ago - see [url]http://www.maz323f.co.uk/forum/viewtopic.php4?t=1189[/url] - about halfway down the topic.
PS : The good news is - you now have a spare reverse light bulb ...
