Club323F • View topic - CV joint.
It is currently Mon Nov 09, 2026 7:25 am
shadowmalik
 Post subject: CV joint.
PostPosted: Tue Aug 31, 2004 2:31 pm
My outer CV joint has joint has gone and am looking to replace it myself.
Has anyone done it themselves and have any advice to give. I would also appreiciate it if someone could tell me the tourque setting for the driveshaft nut and a good way to hold the hub in place when undoing the nut (was a killer on my Renault).
PostPosted: Tue Aug 31, 2004 3:35 pm
I have done VW CV's a couple of times, but not my Mazda yet ....
The only way to get the driveshaft nut off is with a huge socket through the centre bore of the wheel, with the wheel bolted to the hub and the whole car on the ground with a brick either side of the wheel and the handbrake on. You will probably need an extensive extention as well. Don't use a cheap socket set; it will break before the nut comes loose.
