Club323F • View topic - Split at the back
It is currently Sun Nov 08, 2026 2:04 pm
Epitapher
 Post subject: Split at the back
PostPosted: Wed Jul 21, 2004 10:45 am
Hi, guys!
I have a split at the plastic panel at the back (between the lights). Is it possible to remove it without the panel changing?
Thanks!
maz323f
PostPosted: Wed Jul 21, 2004 6:16 pm
I am not sure what you mean by "Is it possible to remove it without the panel changing? "??
Do you mean can it be removed? if so yes, there are 4 bolts (2 on each side), then underneath the interior plastic planels are some more bolts and 3 screws.
Craig
Epitapher
PostPosted: Thu Jul 22, 2004 8:33 am
[b]Maz323f[/b], thanks! But I ment if it possible to remove the split? :)
tucker101uk
PostPosted: Thu Jul 22, 2004 9:15 am
It may be possible if you take it to a bodyshop - they may be able to glue it back together and smooth it over... but then they will have to respray it etc, so its prob gonna be a bit expensive...
Epitapher
PostPosted: Thu Jul 22, 2004 1:29 pm
[b]tucker101uk[/b], thanks for advice! By the way... Do you know exactly if that panel is plastic or glass?
tucker101uk
PostPosted: Thu Jul 22, 2004 1:30 pm
If you are talking about the rear bumper, i think that its plastic...
PostPosted: Thu Jul 22, 2004 2:41 pm
The red bit between the rear lights is plastic.
[b]Mark[/b]
tucker101uk
PostPosted: Thu Jul 22, 2004 3:48 pm
oh... your talkin about that bit... not sute bout that...
Its sort of clear plastic, but i dont know if they can fix that, you may have to get a new one.
maz323f
PostPosted: Thu Jul 22, 2004 6:06 pm
If it is the red plastic bit then yes i can be sprayed over
PostPosted: Thu Jul 22, 2004 9:29 pm
You can be sprayed over ?? lol
PostPosted: Fri Jul 23, 2004 2:10 am
LOL whatever turns you on...
tucker101uk
PostPosted: Fri Jul 23, 2004 9:03 am
I think that Epitapher is talking about the reflective panel which holds the fog light and reverse light... which is clear, and therefore not repairable as such...
Yes it can be sprayed over however this would make it solid, and no longer a clear reflective strip.... depends what you want epitapher.
Epitapher
PostPosted: Fri Jul 23, 2004 6:39 pm
[b]tucker101uk[/b], exactly. You are right. I'm talking about the panel between the back lights, the panel, which holds back fog light and reverse light.
Well... Maybe it would be better to pait it with the original car color. I'll think about this.
