Haha
Yeah well it wasn't working at first, mostly not at all, the wire was broken in half.
I removed it and pulled the wire out, then soldered it with a lighter.
I tested it to see if it's a strong bond, and it was.
Then using a little file I tried to match the tooths, and it worked out fine.
The thing is the bars aren't straight and usually it gets jammed half way or 1/4. Sometimes it doesn t go all the way down ...
I do have a swicher in the dash, with 2 empty wires, maybe I can connect the aerial wire to it, and choose when it goes up or not
