Club323F • View topic - Indicator problems!
It is currently Fri Nov 06, 2026 5:33 am
MrKikker
 Post subject: Indicator problems!
PostPosted: Tue Mar 13, 2012 8:52 am
Guys,
Sunday I was working on the car, removed the radio to fix the DIN-frame. Upon putting everything back together, my car alarm worked but it only flashed the right side indicators of the car. After pressing the alarm button a couple of times, that side died also.
The situation is as follows:
Indicators won't work at all. Not by using the indicator pedal on the steering wheel and not by arming the alarm. The clickerbox is working, clicking fast.
Alarmbutton won't work. When using both the alarmbutton and the indicatorpedal, the clickerbox clicks faster.
I've used a voltmeter to check things out, the relais is getting between 2 and 5v switched, 11.95v continuous, however i'm getting no signal in the wires running to the indicators.
I've put 12v directly on the wires running to the indicators, both the left and the right side work.
Checked the 'TURN' fuse, the fuse is good and appearantly workes as when I remove it, the clickerbox won't work.
Put a groundwire from the relais to the chassis, no effect.
Replaced the relais with another one from another BA, didn't work.
Any suggestions??
I'm running out of ideas!
 Post subject: Re: Indicator problems!
PostPosted: Sun Mar 18, 2012 10:36 pm
Have you tried another flasher unit?
MrKikker
PostPosted: Tue Apr 03, 2012 7:38 pm
oh forgot all about this topic :D
fixed! blew the Hazard fuse in the engine bay.
Farcry
PostPosted: Wed Jun 10, 2015 8:06 am
How did it go from only the right side, to neither side or the indicator levers working, with the cause being one broken fuse?
I am trying to bring my cars wiring up to standard, it's been hacked at, but at the moment only the right side flashes vis the alarm, but otherwise they work normal.
Not that the alarm really works, it goes off for no reason.
