The alarm seems will be in long tamper mode. You will need to reset, and possibly re-program the remotes.
Put the key in the ignition, and turn forward
all the way just before cranking. Then within 5 seconds, locate, press and hold in the valet/overide button, found under the dash area, (push button, spring loaded)
until the installed LED (the blinking light)
in your dash area goes on solid, and the siren chirps once.
(Your valet switch might be the toggle (on/off) type. in this case, key on, flip switch in opposite direction, then turn the key off.)
This should reset the alarm, and reset the grounded relay on the starter wire, allowing you to start the engine.
At this point, the only thing working would be the keyless entry from the alarm, if it came equipped that way.
Just Repeat these steps to place it back to usable armed mode. You may get 2 chirps, confirming it, and the lights may flash twice as well.
found here
http://en.allexperts.com/q/Car-Alarms-1 ... a-5801.htmOR
you hold the two grey buttons at the same time beside the car wait for the light to go out then press the larger one twice thats it job done
http://wiki.answers.com/Q/How_do_you_re ... rm_remotesAlso i have read somewhere that you put the key in the ignition and turn it too the click before the engine starts and then hold down one of the fob buttons, that should get it all working again. I dont know if any of these answers work for sure, but if they dont work you might be better taking it into a garage.
