It is currently Mon Oct 05, 2026 2:50 am
Post new topic Reply to topic  [ 154 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
PostPosted: Thu Mar 17, 2022 9:06 pm
congratulations on the pass, another years motoring, and extra congrats for the emissions too, something which terrifies us all :D
PostPosted: Fri Apr 08, 2022 7:39 pm
So just when I was congratulating myself on getting a MOT for the V6, and thinking I could move on to the BG ...
... I was on a trip a few days ago, and just as I arrived at my destination the car started running poorly and the oil light came on. In a few minutes, the entire 5 litres of new oil I'd put in for the MOT two weeks before, had all peed out the bottom of the car :cry:
I thought I'd left the oil filter loose, or the drain plug. But no. Then I thought the new rear rocker gasket had leaked. But it seemed dry. The sump gasket was also fine.
Then I thought the PCV valve might be blocked, and the extra pressure in the engine caused a leak through the gaskets. But even with a new valve, the oil still leaked out.
Then I noticed this:
A core plug had fallen out of the engine block, and when I did a test and filled up with some new oil and turned the engine on, the oil started pouring out the hole! :shock:
It should look like this (photo from Andy Bowen):
There are two of these on the V6, apparently they cover holes that were made when the engine was manufactured. Mazda still supply these plugs, and for only £8, but it would take a week to get it from Europe, and I didn't have that long. Fortunately with Hughie's help I located a correctly sized core plug for £2 on eBay, and paid to get it delivered the next day:
After filling the hole with a silicon-based sealant, I banged in the plug. It took a while because there is limited room in a V6 engine bay to swing a mallet, but after about 20 minutes of tapping with a small lump hammer it was finally flush against the block all round:
Test drive today ... no leak from the new bung! (the white stuff is sealant I smared around the edge, just as an extra precaution):
However, the car was STILL leaking oil, though only very very slowly. After some investigation I realised that it WAS also leaking from the rear corner of the rear rocker gasket, which I replaced in February ... evidently I didn't do up a nut tight enough. When I looked at the gasket the other day it was dry, but obviously because there was no oil in the engine at that time, I couldn't turn it on to check the gasket when it was under pressure. After the main problem was fixed and the oil was replaced, and I did a test drive, I was able to see the oil dribbling out.
At least it's manageable / sortable, and I don't seem to have a leak from anywhere worse. Fingers crossed ...
PostPosted: Sun Apr 10, 2022 6:22 pm
Wow, you were lucky if you stopped the engine before it ruined the bearings,
Swing a mallet? :badgrin: under there you can't even swing a cat ...
And there was me thinking that core plugs only did the coolant circuit!
Learn something every day.
