Club323F • View topic - To all with smoking exhausts.
It is currently Tue Nov 03, 2026 12:21 am
Post new topic Reply to topic  [ 72 posts ]  Go to page 1, 2, 3  Next
PostPosted: Wed Nov 14, 2007 11:34 pm
Theres been a few threads recently about smoke coming from exhausts, mostly white smoke, or smoke on start up etc...
Water is a by-product of combustion. Put your hand over your tailpipe, it'll be damp after 5 seconds or so.
When warm air (eg-from your exhaust) meets cold air or a cold surface (your exhaust cooling down) it cools down and condenses (turns into water). This water will sit in your exhaust, coating the inner walls of your pipes and silencers until next time you run the car, then the collected water will heat up again, causing it to evaporate and exit the exhaust as steam.
Coupled with the cold mornings this warm steam will be further enhanced as it collides with the cold air after leaving the exhaust. Similar to your breath on a cold day. The colder it is, the more steam you'll get.
If you have a cylinder head gasket problem, and your burning coolant you will notice it. Your car will be running like shit, and your exhaust will be BELCHING white smoke. Your coolant bottle may also be smelling of exhaust fumes.
If you have blue smoke, then this is an oil burning problem.
On start up, when changing gear or on over-run, it could be your valve stem oil seals, oil seeps through them and down the valves into the combustion chambers, then burns with the fuel/air mixture.
If the piston rings are knackered, then the engine will smoke blue when you plant your foot down.
Black sooty smoke usually means rich running, too much fuel in the air/fuel mixture.
If your car is on fire, then theres a good chance this will cause smoking too. You should definately notice this, and its usually coupled with extreme heat and some swearing!!! :wink:
[b]Please eliminate all these possibilities before posting a new thread about your smoke problems.[/b] :thumbleft:
maylander739
PostPosted: Wed Nov 14, 2007 11:57 pm
a good post neil, but you still haven't told us where to get the zxi spleaters from?
[img]http://i30.photobucket.com/albums/c321/maylander739/sig2.jpg[/img]
PostPosted: Thu Nov 15, 2007 12:03 am
Matt, you've been a member here since 2004.
You should know that its spleeters, not spleaters..... :roll:
Murray
PostPosted: Thu Nov 15, 2007 12:13 am
what should i do if my car is on fire?
[img]http://i210.photobucket.com/albums/bb192/Muz1986/Neilyabl00dyedjit.jpg[/img]
PostPosted: Thu Nov 15, 2007 12:25 am
[quote="Murray"]what should i do if my car is on fire?[/quote]
Get out. Quickly. :wink:
Hairy Bob
PostPosted: Thu Nov 15, 2007 12:37 am
[quote="Neil F"]Matt, you've been a member here since 2004.
You should know that its spleeters, not spleaters..... :roll:[/quote]
Actually, it has 3 'e's... SPLEEETER
Good idea for a thread though, it's getting a little boring reading the same thing time and time again.
Incidentally, I've noticed my mouth smoking when it's cold outside... is this normal?
Ad
PostPosted: Thu Nov 15, 2007 12:52 am
This is a very informative thread! Should reduce the amount of questions being asked about smokey exhausts...
[quote="Neil F"]If your car is on fire, then theres a good chance this will cause smoking too. You should definately notice this, and its usually coupled with extreme heat and some swearing!!! [/quote]
So... what you are saying is: get out the car, have a cigarette, stand back and swear at it a few times?
Adam, you know that the hot bit goes on the outside right? :lol:
Dazp1
PostPosted: Thu Nov 15, 2007 1:48 am
lol. I've experienced all of them. The last one not so funny. :lol:
errnee
PostPosted: Thu Nov 15, 2007 10:44 am
Sticky, Sticky, Sticky :thumbright:
PostPosted: Thu Nov 15, 2007 2:39 pm
[quote="errnee"]Sticky, Sticky, Sticky :thumbright:[/quote]
is that what you've been smoking...or just a suggestion? :thumbleft:
egos_86
PostPosted: Thu Nov 15, 2007 2:48 pm
[quote="marcrs"][quote="errnee"]Sticky, Sticky, Sticky :thumbright:[/quote]
is that what you've been smoking...or just a suggestion? :thumbleft:[/quote]
Lmao ...JHokes
ziggy323f
PostPosted: Thu Nov 15, 2007 6:17 pm
valve stem oil seals - where are these located???
PostPosted: Thu Nov 15, 2007 6:20 pm
[quote="ziggy323f"]valve stem oil seals - where are these located???[/quote]
"you blown a seal mate?" - "nah, just a bit of frost on my top lip..."
sorry, couldn't help it, been a long day... :wink:
griff88
PostPosted: Thu Nov 15, 2007 6:41 pm
[quote="Hull_BA"]
Ad[/quote]
lol. stuff a mechanic...ask a doctor..
could also be a eye brow seal on its way out.
griff
RY4N
PostPosted: Thu Nov 15, 2007 7:51 pm
Excellent post Neil.
[img]http://i234.photobucket.com/albums/ee131/ryanincontrol/untitled.jpg[/img]
That's 8 for the inlet and 8 for the exhaust (For 1.5 and 1.8 engines).
Be warned as they look exactly the same and its not hard to swap them around.
if I remember correctly the only difference are the exhaust ones have tougher material or something on them than the inlet ones.
Anothersucker4a323f
PostPosted: Thu Nov 15, 2007 9:41 pm
on the valve stems :lol:
Cylinder head off job if I'm correct, if not I will soon be put in place no doubt :tongue:
PostPosted: Thu Nov 15, 2007 10:49 pm
Hmmm.... tricky one that, I've never experienced a sticky exhaust.... :laughing6:
Hairy Bob
PostPosted: Fri Nov 16, 2007 1:23 am
Mine's crusty... deposits have been accumlating right on the end for months... ain't washed it since the York meet!
Suppose I should give it a good scrub really!
Ad
PostPosted: Fri Nov 16, 2007 2:06 am
your mouth or the car? hehe
m7acx
PostPosted: Fri Nov 16, 2007 1:03 pm
haha.... funny stuff.... :lol:
Good thread Neil F :thumbright:
PostPosted: Thu Dec 13, 2007 8:51 pm
Bumpety bump.... :wink:
Tillerthou
PostPosted: Thu Dec 13, 2007 11:05 pm
i always thought smoke was caused by worn out exhaust bearings.............
you can fix it by fitting cross drilled brakelines and high octane headlight fluid...................
PostPosted: Wed Mar 19, 2008 3:55 pm
Phone Lloyds quickly, and make sure it's insured !!! :lol:
PostPosted: Mon Oct 27, 2008 7:53 pm
Well, it seems to be that time of year again...... :laughing6:
Now a sticky. :wink:
RHRH
PostPosted: Mon Oct 27, 2008 8:47 pm
[quote="Neil F"]If your car is on fire, then theres a good chance this will cause smoking too. You should definately notice this, and its usually coupled with extreme heat and some swearing!!! :wink:
[/quote]
Hahaahaaahahhaa, thats priceless... lmfao... :lol: :lol:
[img]http://www.timeattackforums.com/forums/images/avatars/boost.gif[/img]
parvez
PostPosted: Mon Oct 27, 2008 11:45 pm
[quote="Neil F"]Well, it seems to be that time of year again...... :laughing6:
Now a sticky. :wink:[/quote]
Good job sir :thumbright:
ziggy323f
PostPosted: Tue Oct 28, 2008 12:07 pm
:evil4: Mines 24/7 burns oil every time, but as its soo cold its like a cloud :lol:
scott5050
PostPosted: Tue Oct 28, 2008 1:13 pm
[quote="Anothersucker4a323f"][quote="ziggy323f"]valve stem oil seals - where are these located???[/quote]
Cylinder head off job if I'm correct, if not I will soon be put in place no doubt :tongue:[/quote]
You're not correct. Go to your place!
You can use compressed air or nylon rope down the spark plug hole to hold the valve up while you change the stem seals.
Much easier doing it with the head off but not as much hassle as removing the head.
A L 3 X
PostPosted: Tue Oct 28, 2008 2:48 pm
think my prob is solved now....was some water under the exhaust after i got mum to start it and take a look(she said its the most healthy engine smoke shes ever seen, i'm guessing she means its condensation then lol)
the water didn't smell either
Ringo
PostPosted: Wed Oct 29, 2008 9:48 pm
[quote="A L 3 X"]
the water didn't smell either[/quote]
At least now you know nothings pissin on your car aswell innit! :lol:
