Club323F • View topic - EPC Favours
It is currently Wed Nov 04, 2026 10:37 am
Post new topic Reply to topic  [ 531 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18
 Post subject: Re: EPC Favours
PostPosted: Fri Oct 05, 2012 12:19 pm
Can some one look up brake proportional valves for me please,
I need to know if there is any difference between the following:
323F 1.5
323F 1.8
323F V6 NON ABS
323F V6 WITH ABS
hope fully the 1.5 and 1.8 will be the same and the V6 non abs and with abs will be the same!
Thank you
Nathan
Shayne
PostPosted: Sun Oct 14, 2012 1:13 pm
Hi, I have a full lock set with ignition barrel, 2 door barrels, boot barrel and a glovebox barrel. I need to check which car it is for, was told that it is for the BA but it doesnt have a chip facility for the immobiliser.
Could someone possably check this part number which is attached to the complete set.
GG 65 BS87D
below the bar codes is the following: R 00 K7400 10201 J
Tag on the key ring also has the 10201
Much appreciated
Shayne
Shayne
PostPosted: Mon Oct 15, 2012 6:25 pm
Nag nag, just to get it up top, sorry.
Shayne
PostPosted: Tue Oct 30, 2012 7:23 pm
bump
PostPosted: Tue Oct 30, 2012 7:31 pm
[quote="323F Rock"]Can some one look up brake proportional valves for me please,
323F 1.5
323F 1.8
323F V6 NON ABS
323F V6 WITH ABS
Thank you
Nathan[/quote]
they're not the same mate
I think i got all of them saved on my comp from when i sourced parts for the BPT will look for you now
PostPosted: Tue Oct 30, 2012 7:53 pm
cant find them
Have to try and describe
For v6 ABS
There are 2 pipes coming from the master - they go into the abs controller
from the abs controller 4 pipes come out
2 go to the front wheels
2 go into the prop valve and come out other side to rear wheels
V6 without abs
2 pipes come from master - go into prop valve
4 pipes come out of prop valve, 1 to each wheel
I think the only reason the ABS one has a "prop valve" is so that the rear pipework is the same on all cars up to the prop valve, it looks like the abs unit actually controls the proportioning as this is where the 2 pipes go to 4..........
PostPosted: Thu Nov 01, 2012 2:17 pm
bugger bugger bugger... looks like I'll have to get this then: http://www.wilwood.com/MasterCylinders/ ... =260-11179 :lol:
cheers Matt,
Have you got the part number for prop valve for the V6 without ABS please?
Nathan
Shayne
PostPosted: Thu Nov 01, 2012 2:29 pm
Can anyone help with my request for this part number
GG 65 BS87D
Much appreciated
Shayne
Shayne
PostPosted: Mon Jan 14, 2013 1:18 pm
Nag nag nag, is it possible for someone to check this for me please, thanks
AeroX
PostPosted: Tue Jan 15, 2013 3:58 pm
[quote="Shayne"]Can anyone help with my request for this part number
GG 65 BS87D
Much appreciated
Shayne[/quote]
I've tried to look up "GG 65 BS87D" today but get no matches (might be me doing something wrong though, not that experienced using EPC)
- AeroX
Shayne
PostPosted: Tue Jan 15, 2013 4:03 pm
Thanks mate, I appreciate ytour efforts.
PostPosted: Tue Apr 23, 2013 10:33 pm
Ball joint help needed ladies and gents, I'm not near my EPC :?
When we swapped the hubs on Meanie for 1.8 hubs from the doner car for the turbo GTR, we had a slight concern about the lower ball joints.
I'm not sure if they are 18mm or 16mm, the Leamington Mazda parts guy was no help, reg number is P821 HKO, chassis number JMZBA14P201384571!
I know there is a cutoff point where the production switch was done, anyone give me a clue, or confirm size? Kinda in a hurry too, gotta do all the work Saturday for the MOT next week.
Cheers in advance :)
PostPosted: Wed Apr 24, 2013 10:07 am
[quote="andym323"]Ball joint help needed ladies and gents, I'm not near my EPC :?
Cheers in advance :)[/quote]
Hi Andy it says:
Ball Joint, Lower
B01A-34-550A
AN (BTDA-34-550)
PostPosted: Wed Apr 24, 2013 8:37 pm
Thanks guys :thumbright:
Back on the EPC myself now, looks like Meanie has the 18mm, same as the donor car, I'm gonna change them out anyway I think :)
I nearly choked when the Leamington Mazda guy told me how much they charge for them, £72...... EACH :shock:
Car Spares for me :p
PostPosted: Fri Aug 09, 2013 1:13 pm
hey there everyone. Please can someone get me the mazda part number and the actual part number for the knock sensor on the v6 (only found on imports). Thanks in advance
PostPosted: Fri Aug 09, 2013 10:49 pm
Dont think imports are covered on the EPC mate
AeroX
PostPosted: Sat Aug 10, 2013 11:59 am
[quote="eogbaker"]hey there everyone. Please can someone get me the mazda part number and the actual part number for the knock sensor on the v6 (only found on imports). Thanks in advance[/quote]
[img]http://mattjj21.co.uk/dump/251.jpg[/img]
^ Closest I could find. Not sure if it's the sensors there or just the bracket for it.
- AeroX
PostPosted: Sat Aug 10, 2013 12:18 pm
hmmmm cant see it in that diagram. thanks for the help. I will try and go to mazda and see what they say
marshymob
PostPosted: Tue Nov 03, 2015 10:27 pm
My Car: Julie - 1994 BA
any peeps around to help out a lady that is suffering from the cold.
Julie needs a new heater matrix, does the epc list the part number for the 1.5 ba
found one for a 1.5 but no part number only suggested it will fit
so any help will be great 8)
PostPosted: Sun Sep 04, 2016 10:49 am
Rich, whats the reg number mate?
PostPosted: Sun Sep 04, 2016 10:50 am
Having said that, I'm guessing you've fixed it by now? :laughing6:
