It is currently Sat Jul 21, 2018 6:53 am
GUIDES ONLY please.
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2
oscar bj
PostPosted: Sat Jun 02, 2012 1:28 am
Aha mazda through trade cost 33 quid. I had two different filters from parkers. Not ised them since
johnboysupergolf
PostPosted: Thu Feb 28, 2013 12:03 pm
What an excellent and well thought out tutorial
Guys is this relevant to my o3 plate 323 sport.
The part number zl-05-20-490a am I right in saying that this is the filter part of the fuel pump as shown above, and that this filter can be purchased and fitted onto the fuel pump as shown above.
Thanks in advance.
PSABIN8951
PostPosted: Wed Jul 10, 2013 11:31 am
Has anyone found the base of the replacement filter to different?
I got a genuine ZL05-20-490A filter and found the base was just a round hole with no pins for strap to retain low pressure filter.
Is there another part number I should use?
Anselmo81
PostPosted: Thu Jul 11, 2013 9:39 am
How crucial are the 8 screws that hold the pump+filter in place?
Mine are damn corroded, I'm pretty sure some of them will snap while
removing them. Will it hold tightly in place if I replace, let's say, 6 of them
and just knock the heads of from the most corroded ones to get the pump out
and leave the remains of those screws in.
Impact driver might do the work for most of them, but there are few that doesn't have anything left of the Phillips pattern.
PostPosted: Wed Aug 21, 2013 9:59 am
probably too late now but don't pop the heads off!!
try using a screw extractor like this:
http://www.tesco.com/direct/6-piece-dam ... tAod3mIA-g
Our little kit was from Lidl and it worked beautifully on ours screws around the fuel pump :D
The 323F GTR 1.8 Turbo
TheMAN
PostPosted: Fri Nov 08, 2013 11:44 pm
I determined why many people have stripped the fuel pump screws... yes, rust is a big factor, but the fact that they are very tight from the factory means even with typical screwdrivers you can easily find at shops will strip the heads because Japanese cars use JIS crosshead screws! they look so similar to Phillips head screws that everyone mistakes them for that. No longer for me!
the biggest difference is that JIS screws and its drivers have very different tip angles as opposed to Phillips head or Frearson (very rare on cars) head screws
therefore, it is utmost important to use a proper JIS screwdriver to remove these screws and all other crosshead screws in Japanese cars! It's no wonder why I have stripped so many screws in the past!
Find a Japanese made screwdriver and you shouldn't go wrong
Article describing the issue in detail:
http://www.vesseltools.com/downloads/re ... 013_02.pdf
Protege FAQ, the best 323/Protege/Mazda3 resource enjoyed worldwide for 10 years
PostPosted: Fri Nov 08, 2013 11:51 pm
cool. learn something new everyday
Zippy
PostPosted: Sun Nov 10, 2013 10:10 pm
Ooh, thanks for that Man. Might use the impact driver and replace the screws coz it's easier :badgrin:
dml6881
PostPosted: Mon Jun 02, 2014 4:35 pm
I need to do this asap as its feeling sluggish.. Can some one tell me where I can purchase this filter and is the part number still the same.
Any help would be grateful.
Just bought a 2000 Sport BJ with no history so its piece of mind.
PostPosted: Wed Jun 04, 2014 10:38 pm
Hi, I'd say Mazda dealer would be pretty much the only place to get one, be prepared for a fun quote though, they might even try and sell you a whole filter! :roll:
I would just take it out and clean it.
Roc
PostPosted: Wed Jun 04, 2014 11:48 pm
I keep in tank filters for bj.
Stocked them for about 5 years. Club members asked me to stock it.
http://www.fordprobestore.co.uk/store/p ... ts_id/1489
dml6881
PostPosted: Thu Jun 05, 2014 8:10 am
Cheers. It's on my list of to do's so I'll be having the filter next week potentially. What's delivery time (uk) and do I need anything else?
Roc
PostPosted: Thu Jun 05, 2014 11:08 am
A couple of days delivery.
Checking stocks with manufacturers, these are getting quite low and rare, might be a plan for anyone doing this soon to order and keep, just in case.
HMC
PostPosted: Mon Aug 10, 2015 1:16 pm
I also have a BJ (1.5) and I want to change the fuel filter but I'm not sure where it's located.
Do all BJ's have in tank filters?
If you search for fuel filters for BJ's you'll find 2 different types :roll:
Examples:
or
http://www.fordprobestore.co.uk/store/p ... ts_id/1490
Anyone knows for sure which one is it? :)
aircraftmech
PostPosted: Tue Sep 22, 2015 2:27 pm
Anonymous wrote:
I tries eurocar parts for this filter and it was the wrong one ! Mega bummed about it!
Euro car parts have the correct in tank fuel filter for my car, BJ model 1.6 with ZM engine. The euro car parts item code is 50368026J and is £19.99. Fits perfectly all be it a pain to get to but enjoyed doing it!
jjoblogs
PostPosted: Tue Jun 14, 2016 9:32 pm
Hi have looked at the pics very furrah nice post ,
just an add on,the b""t^^d bar thats in the way?
(pic 2 opposite torch),
if you know anyone thats good at cutting and welding,
just cut it out elongate for future ,placing flat head bolts to compensate for seating etc etc,
just in case you have to do it agin sometime
Flower10
PostPosted: Fri Aug 19, 2016 1:38 pm
Hello, guys! If you need some inspiration, you're welcome on this source where you can find out plenty of amazing articles as well as improve your knowledge http://bigpaperwriter.com/blog/life-cha ... ence-essay
