It is currently Sun Jan 20, 2019 8:06 am
Post new topic Reply to topic  [ 67 posts ]  Go to page Previous  1, 2, 3
PostPosted: Tue Nov 03, 2015 2:27 pm
most odd...unless it didn't all drain out?
Beatwolf
PostPosted: Sat Nov 14, 2015 8:52 pm
Pretty sure it all drained out. Now i'm getting 2 cm's or so above the full line. Is that dangerous?
PostPosted: Sun Nov 15, 2015 10:19 pm
Sounds high...are you checking it on level ground?
Beatwolf
PostPosted: Mon Nov 16, 2015 7:44 pm
Yeah I was. What is the best way to check it, after having driven a short while, and then letting the engine cool off for 5-10 mins or?
PostPosted: Tue Nov 17, 2015 2:21 pm
Yeah, leave it long enough for the oil to settle again, 5 minutes should be plenty.
Sometimes it can be tricky to read on the dipstick, I've had cars where oil seems to sit on it, and they show the same level no matter what's in the engine...need to check both sides of the stick too, one side might be correct, while the other might drag oil from the tube it sits in and give a false reading.
JapanNo1
PostPosted: Sun Jul 29, 2018 4:55 pm
hello , i have a mazda 323f bg 1.6. 16v from 93 , i bought the car at 177.000 km and the previous owner already had a 10w40 castrol oil in the trunk so i went with it and i used the exact same oil , now i'm getting close to 187.000 km and the engine consumed a little bit of oil , i would actually say a tiny bit , maybe 100-200ml or so
what oil do u guys recommend to use now?
PostPosted: Sun Jul 29, 2018 7:35 pm
Castrol 10w40 should be fine, I use either GTX or Magnatec, whatever is on offer.
The main thing is to change the oil, rather than not change it :o
and...
I use a main dealer filter, i.e. not a cheapo copy. I think that's important.
P.S. There's a separate oil change thread running on here somewhere ...
