It is currently Sat Jun 23, 2018 1:52 am
rwickham2001
 Post subject: BG 3 door compatibility
PostPosted: Wed May 10, 2017 11:42 pm
Not having too much luck on here lately, but some guidance would be amazing.
As mentioned in my wanted post, i need a rear wiper and A pillar trim for my car. I know for a 3 door 323 bg (89-94) that is being broken. So, basically i need to know the compatibility on 3 parts i need.
1. A pillar trims - they look similar but are they the same between models.
2. Rear wiper module - I've tried google searches to compare but nothing is clear.
3. Trim or seal that runs between the windscreen and roof edge - thought maybe the windscreens are the same size?
The car that's being broken is too far to just pop down and compare. Any experts care to impress me?
Stjepan
PostPosted: Thu May 11, 2017 10:21 am
Location: Velika Trnovitica, Croatia || Own: '90 Mazda Astina 323F BG
1. A-pillar trim not same... They just look same but they isn't...
2. Rear wiper - not sure... Use your wiper module in hand and go to check. That is the best way. Not to that car... Go to friend who have 3-door Mazda BG.
But when I think, they can be same , because rear trunk door are quite different...
3. Windscreen size is not same... I have measure for bout from store where I have buy windscreen...
3-door BG
5-door BG (pop-up)
rwickham2001
PostPosted: Thu May 11, 2017 10:39 am
Thanks again Stjepan.
Gutted about the A pillar trim as I thought I'd found a solution. Back to trawling eBay for now......
Good idea to check someone elses 3 door BG, but I don't know anyone. Nor have I seen one on a UK road for a long time.
It doesn't surprise me that you said the windscreen's are different sizes, however the diagrams you put up for the 3 and 5 door are identical :scratch: . Can you confirm?
Cheers :salute:
Stjepan
PostPosted: Sat May 13, 2017 7:58 am
I will cut my a pillar trim from some aluminum... Because that trim is too expensive...
Sorry for pics... And late respond... Windscreen size definitive no identical...
I will update one of them... I think that my f**king laptop not copy link property... :x
EDIT: Pics are updated...
duwaine1.8gti/rx
PostPosted: Thu May 18, 2017 1:04 pm
Hi Rwickham How's the parts list getting on.... I do have a rear wiper module If you still need it
rwickham2001
PostPosted: Thu May 18, 2017 1:19 pm
Hi Duwaine, I do still need one. Thought i have to bodge the broken one with bits from the good BA wiper I have. How much would you want for it posted? Take it you can't help with the A pillar and windscreen trim? Cheers.
duwaine1.8gti/rx
PostPosted: Thu May 18, 2017 1:50 pm
Hi Rwickham no sorry I can't help with the trim and A pillar sorry m8t. Can you pm me your details so I can get postage costs cheers. Don't give up 8)
