It is currently Fri Aug 17, 2018 4:19 am
Foreigner323
 Post subject: Light problem
PostPosted: Thu Jul 28, 2011 12:58 am
Hi :p
could anyone please tell me where does the interior lamp and the sound warning system are attached to metal??
I can't find the ground wire!! I know that the problem is the ground wire but I still couldn't find him..
Jack Morgan
Aftertouch
 Post subject: Re: Light problem
PostPosted: Tue Aug 02, 2011 11:43 am
If i remember correctly,
the wires of the interior lighting goes directly into the fusebox (small plug)
Only the switches @ de door are grounded... but dunno where. :oops:
PostPosted: Tue Aug 02, 2011 11:46 am
the switches ground at the switch, the body of the switch connects to the body of the car with the screw, making the ground connection ;)
they usually fail at some point, corrosion gets the better of them...take them out, clean them up, and re-fit them :)
Foreigner323
PostPosted: Tue Aug 09, 2011 1:35 pm
om thanks for the help guys.. i will try do that..
