It is currently Fri Aug 17, 2018 4:19 am
Post new topic Reply to topic  [ 29 posts ]
Ben_P
PostPosted: Sun Apr 22, 2007 11:22 pm
This is a guide on how YOU could build a couple of 10” subs into the annoying little corners of the BG boot. I would like to stress however that I am in no way a sounds and ICE expert, and that I only built the speakers where they are because they fit and are out of the way. Cos like most I like to fit the shopping in my boot!!!!
What I was hoping to achieve was something that looked like this
Designing the Mount
The first step is to mark out the area needed, I however did this by using a piece of cardboard and marking out the contours with a pencil. This however can take forever and you will be happy to know that after finally cutting out the cardboard and getting it to fit I then made an MDF one.
This stage is all trial and error.
I then (just for any of you guys) drew round these MDF templates onto paper so that anyone who wants a plan can PM me and I will send them out to you.
I used 12mm MDF, to save weight.
Holding the Mount in place
To hold the mount in place you will have to hold it at the top and the bottom.
The top is easy as I created a single plate that fitting directly into an existing screw hole, and to my amazement the existing screw was like 50mm long and was able to hold the mount as well. This saved me having to think up other ways of mounting the top. I also have plans for these. I used a piece of fibreglass sheet I had lying around but anything will do.
The bottom took me a little longer but I did come up with a way of doing it. I used a piece of 12mm trunking, the type you use to hide cables in houses. The MDF fits in well. The placing for this is easy. Right at the very back of the boot below the light clusters inside you will notice that there are two (one each side) pieces of plastic, like shown below. The trunking will sit behind these, this can also be seen below.
You should now have something like below.
After placing the trunking like in the picture I carefully used two self-tappers to mount them to the base of the boot. This will be ok as there isn’t much underneath, but always best to check BEFORE drilling.
The holes for the subs are to fit the 10”subs I had. I would like to stress that these only just fit, bigger subs will not fit in these mounts. Smaller one will be fine; just don’t cut the hole so big!!!
Being subs they will need some holes to allow airflow. I made holes but then covered them in the fabric. I would have thought the air would have passed thought the fabric ok. This can be seen below. I made 4 small holes about an 1” in diameter.
When it comes to covering the subs and mounting them its always best to drill the sub holes first, then cover and then use a scalpel just to cut incisions small enough to get the screw through. If you try to drill after covering you will find that the fabric will get caught round the drill bit and tear, or stretch and then it will look b*ll*cks.
I use spray mount to keep the fabric in place and then staple gunned the fabric round the corner. This will then keep it in place.
Then mount the subs.
And you should have something like this.
I then proceeded to mount the amp onto the side of these speakers ‘cases’, as I too like to be able to use the car with the back seats down, for moving large objects. This way you can do this. (Previously mounted on the back of the single fold down seat.
Best to wire this as you go.
The best bit is that they are easy to take out if for any reason you no longer want subs in the boot.
PM me if you want plans. :cheers:
PostPosted: Sun Apr 22, 2007 11:52 pm
Looks pretty damn good mate, well done. :thumbleft:
whitedragon
PostPosted: Mon Apr 23, 2007 9:27 am
I'm liking it! Although what happened to those air tunnels?
Ben_P
PostPosted: Mon Apr 23, 2007 12:26 pm
scrapped it. crap idea anyway, this is much easier
cyberpaddy66
PostPosted: Mon Apr 23, 2007 7:19 pm
Oh my god!!, now the Mrs is liking this idea I'll have to get more money out from the piggy bank LOL
Lex
PostPosted: Mon Apr 23, 2007 7:41 pm
You've gotta be loosing some well needed bass in there?
mercuryfrost
PostPosted: Sun Aug 26, 2007 5:28 pm
and he never filled his rear windscreen washer again..
NMMotorsport
PostPosted: Sun Aug 26, 2007 6:02 pm
yer i might do this with mine soon, its a pretty cool idea, keeps boot space and u have a sub :) id have build the amp into the mdf as well though
mazz
PostPosted: Sun Aug 26, 2007 7:36 pm
i cant wait to do this,
down grading time, need space for the wheel chair an shopping,
ben wen ya can get ya ass round mine an we do a modding day :D
anyone else whos wanting to join in is welcomed ova :)
Club 323 swindon division :)
Fleet of 8 & still going strong 8)
Nes, Ghost, White shite 1, White shite 2, Messiah, Kgb, Bug & Riot
www.reefgeeks.co.uk
Ben_P
PostPosted: Thu Aug 30, 2007 7:23 pm
just a few extra pics for you,
i've done a few extra things to the boot build, added some speaker grills.
here you go have a look.
let me know what you think.
and mazz when ever i get a free moment i'll be across.
anybody else is more than welcome to join us.
SstennizZ
PostPosted: Thu Aug 30, 2007 8:57 pm
where'd you get those speaker grills mate?
Ben_P
PostPosted: Thu Aug 30, 2007 9:00 pm
bought them form the http://thebassbin.co.uk/
but i wouldn't recommend them, it took forever for them to post them.
paul323f
PostPosted: Fri Aug 31, 2007 7:36 am
Looks great mate, top job :D
whitedragon
PostPosted: Fri Aug 31, 2007 10:12 am
Looks awesome Mate :thumbright: top job!
And depending when it is, we all need a good modding day, and I need my door painted (as well as other bits) ;)
M
PostPosted: Sun Nov 04, 2007 2:58 pm
well done mate!
still a lot of boot space to spare!
cyberpaddy66
PostPosted: Mon Nov 05, 2007 7:04 pm
Looks brilliant, shame I need that space for my battle box :(
bounce.audio
 Post subject: Beltin idea pal
PostPosted: Fri Oct 17, 2008 10:38 pm
www.bounceaudio.proboards.com
cyberpaddy66
PostPosted: Wed Oct 22, 2008 3:17 pm
Site needs login (rolls eyes)
mazz
PostPosted: Wed Oct 22, 2008 3:23 pm
got an even better boot build ;)
12" sub, x2 amps , powercap and a PC!
and still loads of room to spare :lol:
www.reefgeeks.co.uk
cyberpaddy66
PostPosted: Wed Oct 22, 2008 3:28 pm
I'd say nice tidy boot but it's filthy LOL
mazz
PostPosted: Wed Oct 22, 2008 3:29 pm
lol same as its bike oil. cant seem to shift it. :(
whoever thought it was a good idea to have a cream boot needs shooting!
www.reefgeeks.co.uk
cyberpaddy66
PostPosted: Wed Oct 22, 2008 3:30 pm
You tried the Hellfrauds fabric cleaner, it got permanant marker off our grey door panels ;)
mazz
PostPosted: Wed Oct 22, 2008 3:34 pm
means i got to go to hellfrauds....
humm might just dye the boot black.....
www.reefgeeks.co.uk
offshore4ft
PostPosted: Wed Oct 22, 2008 5:34 pm
Looks good mate, i'm thinking of something similar to this too but reckon it would look better if you carpeted the whole of the side panels, maybe that way it would blend in more and look more stock?
he11boy07
PostPosted: Fri Aug 12, 2011 12:09 am
what fabric did you use ?
i need some for my boot build -.-
lewp91
PostPosted: Fri Aug 12, 2011 11:23 am
he11boy07, this thread is mighty old :P
acoustic carpet is your best bet, most car audio shops online stock it, :)
he11boy07
PostPosted: Sat Aug 13, 2011 9:02 pm
i know but i wanted to know the carpet ;)
Cheer's dude!
epiphone
PostPosted: Tue Aug 23, 2011 12:48 am
Anyone have the templates for this boot build?
I pm'd Ben_P but haven't heard anything back yet.
lewp91
PostPosted: Tue Aug 23, 2011 9:50 am
he doesnt really visit the forum much anymore... he may eventually get your pm via email notification, but your best bet is to make one with cardboard :)
really isnt to hard ;)
i make everything from blanking plates to engine and intercooler mounts with cardboard first :P
