It is currently Fri Aug 17, 2018 4:00 am
diesel323
PostPosted: Fri Feb 16, 2018 10:26 pm
I have a problem with my radio, which keeps loosing the radio signal, CD is working fine. I think the problem is something to do with the aerial? Checking the manual there is a connector near the base of the aerial (under the roof panel) How do I get access to this, preferably without removing all of the roof headliner?
Stu.13
PostPosted: Fri Feb 16, 2018 11:06 pm
My Car: BJ Sport
You can get to it from the tailgate. Just ease down the roofliner enough to get to base of the aerial.
diesel323
PostPosted: Fri Feb 16, 2018 11:45 pm
Thanks.
Do you have to remove any of the plastic trims? rear seat belt top linkages?
Stu.13
PostPosted: Sat Feb 17, 2018 12:11 am
My Car: BJ Sport
It was a while ago I had to do it. I think you just ease it out from the rubber seal and pull it down enough to access the nut holding the aerial in place.
Zippy
PostPosted: Mon Feb 19, 2018 11:19 pm
If you want to lower the roof lining, the bolts are by the grab handles, otherwise you just pull. Poor signal is normally an earthing issue. I do have my aerial going spare if needed!
diesel323
PostPosted: Fri Feb 23, 2018 1:47 am
I managed to gain access to the aerial by taking out the three retaining pins on the roof panel near the hatch door, which gives you just enough room to get at the aerial. In the end the problem turned out to be a bad connection on the radio end, hopefully it's all fixed now. :)
