It is currently Fri Jul 20, 2018 11:14 pm
fsdedtse
 Post subject: Rose joint drop links
PostPosted: Sat Jun 06, 2015 10:58 am
I have been searching the Internet for drop links for my f as when I fitted my rear coil overs there drop link plate was was a good 100mm higher than standard. So it got me thinking about making my own up with automotive rose joints. They will pass the mot with them as long as you get the rubber boots that cover them. I no there is more maintenance with them but they seem like a better option than standard drop links as they would be completely adjustable to user preference. Best website I found was this http://www.mcgillmotorsport.com/rod-end ... cessories/
The pricing seems reasonable and comes from a reputable company. So I've ordered what I need and when they turn and I've fitted them I will leave my feedback for them. What are your thoughts on Rose joints?
stuartspel
PostPosted: Sat Jun 06, 2015 6:14 pm
I made my own with rose joints and SS threaded bar. Much much better quality than the normal drop links that ebay horrendously sells. think there is a post on here somewhere...:scratch:
AND yes, they pass the MOT too :thumbup:
and cleaned up your other posts, understand - no worries :)
Maikel
PostPosted: Fri Jun 12, 2015 5:47 pm
Okey, I don't have BJ, but I have Premacy, wich has same suspension as BJ.
But the point, I have BC-coilovers installed now. I use 626 GE droplinks in rear. They are just under 100mm long, so they fit fine in there.
fsdedtse
PostPosted: Sat Jun 13, 2015 9:05 am
Im using ta teknix coilovers so not sure if the link point is the same as the drop link i needed was 285mm centre to centre.
JDM323
PostPosted: Fri Aug 07, 2015 10:25 pm
Series 1 (pre facelift) bj has longer rear endlinks, that's what I used for my racingbeat rear swaybar install.
