It is currently Tue Feb 20, 2018 2:59 am
Post new topic Reply to topic  [ 79 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Jun 22, 2016 10:51 am
One of my friends said that if you freeze the intercooler with fire extinguisher it will be better.. :drunken: he's Maad.. but maybe it will be better,i don't know..
MadazInBris
PostPosted: Wed Jun 22, 2016 11:39 am
Someone mention my name ? :lol:
As a physics lesson it will work :idea:
Just don't use the dry powder type ! :shock:
tekkenfan
PostPosted: Thu Jun 23, 2016 4:17 pm
From what I know You can use
- Nitrous (expensive)
- CO2 fires extinguisher (but it can stall engine)
- alcohol mixtures sprayed as a mist on IC
- water mist
Is this what You meant?
MadazInBris
PostPosted: Thu Jun 23, 2016 4:44 pm
Not while it's RUNNING ! :lol:
PostPosted: Thu Jun 23, 2016 10:02 pm
Yep, right before the start.Lowering the temperature of the intercooler
so it cools the air better from the verry start -> 0km/h.
The equation: more dence air(more Oxygen) + more fuel = bigger BANG!! and better start..
and thus better time on 400m..
tekkenfan
PostPosted: Thu Sep 15, 2016 10:45 pm
Up up up :D
After breaking tilton twin discks and input shaft on 02M gearbox I decided to use this opprotunity for a small upgrade:
Last sunday I went to Turboscheune Test & Tune in Finsterwalde. After arrival it was time for first adjustments after changing PB to ethanol. Plan was for 2-2.2 bars of boost hower I wasn't able to get this, and despite my efforts I did get only 1.9. To be honest I was hoping for bigger change between 1.5 bar on PB compared to 1.9bar on Ethanol. I guess I'm being hold by small exhaust side of Holset (8cm). Nevertheless I did some passes and was able to make really good PB for car power and weight:
1 pass - 12.217 (throttle linkage fell of after changing to 4th gear)
2 pass - 11.174
3 pass - 10.911
4 pass - 10.698 (best ET that day. in my opinion really good time for ~500HP and 990kg :D)
5 pass - 10.897
6 pass - 11.566 (after changing to 4th gear car startet to run on 3 cylinders, and after slowing down it died)
Timeslips:
1st pass
[img]https:://scontent.fwaw5-1.fna.fbcdn.net/v/t1.0-9/13245214_1685460228441404_9154571985368783839_n.jpg?oh=e396869a530b44f4568b5ab4d3d062c7&oe=587B32F0[/img]
4th pass:
last pass with engine failure after shifting to 4th gear
TTT is great event and if someone is saying different he's lying ;). I'm making this a must in my calendar hehe
Also changed jeep wheels (11.5kg) to Centerlines (6kg):
Movies:
Onboard:
duwaine1.8gti/rx
PostPosted: Fri Sep 16, 2016 10:00 pm
Nice upgrade :drunken: just want to say congratulations :notworthy: Amazing figures from the bp and the sound awwwwwwww :drunken: :bom: .
Oh and by the way what do you mean it's died :?:
tekkenfan
PostPosted: Sun Feb 12, 2017 2:56 am
Sorry for no updates but it was crazy period of time and lost tracking where I wrote and where not. I hope you can forgive me :D
So back to the subject.
There was no big failure. Shim for regulating valves fell of the valve and didn't allow it to close:
After this I bought new shims, but this time they are mounted on buckets not valves. Hope this will help. Hope because I didn't have proper opportunity to test it.
Together with new shims I made some "adjustments" in body ;).
30kg less:
made almost one peace front (welded hood with lamp covers and grill?)
Made hood vents:
Holder for laptop, and installed N2o system :evil:
Removed air filter and made 4" aluminium pipe sticking out in front bumper:
This picture was taken at TTT on 09.10.2016. Unfortunately weather had different plans and it was raining all day so there was not even one pass :(.
Came back home and finished Drag Wing and at 26.10.2016 went for last TTT to push everything I can from this setup:
Once again it didn't end well :(. Made 2 weak passes and in 3rd one (I think) engine started to work on 1-2 cylinders less. First thought was that again shim fell of so removed head cover checked it and everything was ok. Changed spark plugs, coils etc - nothing. Last try was to remove fuel rail and blow through injectors. After this car started to work like it should. So all happy went to make a pass.
Made a burnout, staged, and go. 1st gear, 2nd, 3rd and again engine not running on all cylinders. After 2 more attempts to clean injectors it was getting only worse, so I had to throw in the towel. I was super angry because car was pulling like crazy. When I made 10.69 I could get more then 1.9bars of boost, and on now I was getting boost cuts on 2.4 bars. If car would be running like it should I guess I would shave a few tens of a second from las PB. But what to do.....
Before this season I made a Stainles steel fuel rail which I hope will be a remedy for all fuel problems and I will get to low 10s (fingers crossed):
Stay tuned ;)
duwaine1.8gti/rx
PostPosted: Sun Feb 12, 2017 12:33 pm
Hi Tekkenfan your welding is coming on really well great craftsmanship. Sorry to hear about your fueling problems m8t hopefully you can get it sorted and dominate the competition. keep up the good work 8)
tekkenfan
PostPosted: Sun Mar 19, 2017 11:24 pm
plans went out of the window hahaha, and now I have to make new exh. manifold and piping:
tekkenfan
PostPosted: Sun Apr 23, 2017 7:59 pm
slowly moving forward:
p4yne
PostPosted: Tue Apr 25, 2017 7:13 pm
Amazing work in this BG, I am very pleased to follow the evolution of this project :thumbleft:
duwaine1.8gti/rx
PostPosted: Fri May 19, 2017 7:33 am
Pm you :D
tekkenfan
PostPosted: Mon May 22, 2017 5:26 pm
so exhaust manifold is done:
it turned out that IC is to high:
So I modified it:
Pressure tested and afeter few corrections it was ok:
Had to relocate radiator:
With new position I had to modify it as well:
That's how finished "product" looks like:
I'm really happy with how it all turned out. I hope it will work as good as it looks hehe.
Also made a test of my manifold:
Sad part is that I wasn't able to start the car to see at what gear I will get boost hahaha.
There is some issue with injectors or their adapters so I have to buy new adapters first and hope it will solve the problem
duwaine1.8gti/rx
PostPosted: Mon May 22, 2017 8:00 pm
There is some issue with injectors or their adapters so I have to buy new adapters first and hope it will solve the problem[/quote]
Looking good keep up with the good work, hope you solve it with the new adaptors.
tekkenfan
PostPosted: Mon Jul 03, 2017 10:18 pm
It turned out that all injectors are seized. I connected them directly to battery and it was just sparking so the coil should be fine... Luckily I had old siemens 850cc injectors. Idle (oil was about 60 deg.)
This allowed me to start the car and do few pulls on 2nd gear. I was really surprised how it went. Turbo is spining on idle (~1100rpm), and during 2nd gear pull with retarded ignition and boost controlled only by WG springs I did get 1 bar at ~5600rpms :O.
new tires (26/10 R15 vs 185/65 R15)
Max turn radius hahaha:
Fancy pancy exhaust tips:
Last weekend I went to TTT for real 1/4 mile testing. Long story short a lot of problems with fuel system (plenty of corrosion inside fuel lines and tank). However this time I was able to do few runs. No PB this time but weather condition was far from perfect, I couldn't get stable AFRs and a lot of problems with going from the hole (I almost stalled engine few times).
Best time from that day - 10.89 @ 193km/h (4th gear poped off and I had to put it again ......)
and best photo from that day (if not ever ;) )
PostPosted: Mon Jul 03, 2017 10:55 pm
:tongue9: :tongue9: :tongue9: :tongue9: :tongue9: :tongue9:
MAAAD!
:thumbleft:
tekkenfan
PostPosted: Mon Sep 18, 2017 8:16 am
Boys and girls I'm back with great news. On saturday I wend to TTT event in Gemany where I manged to join 9s club :D
Data from Racelogic:
Video from 9.942s pass:
Onboard from this pass:
PostPosted: Mon Sep 18, 2017 11:21 am
wicked ! 8)
